Resource Related Fields
Standard Rate
Standard Rate
Type of the field
Edit box with spin control
Rate
Description
Rate is used to calculate cost associated with a resource assigned to a task. Rate for work resources can be defined per minute, per hour, per day, per week, per month, and per year. Default rate is per hour. Rate for material resource is per unit (e.g. per ton).
Related Fields
Maximum Units
