Project defaults are global project settings. There are two types of
defaults:
- Project Options – These options are
applicable to a particular project and are saved in the project
file. You define project options on Tools -> Options.
- Global Options - These project defaults are
applied to all new projects and are saved in the system registry.
Global options include default risk properties, default risk
outcomes, and default values of project options. You save global
options clicking on Set as default in the tabs that support defaults
in the Options, Risk Outcome, and Risk Properties
dialog boxes.
The Options dialog box includes seven tabs. Use the:
- View tab to setup general project parameters and the
appearance of the desktop
- Duration tab to define calculation of task durations
- Calendar tab is responsible for calculation of project
schedule
- Units tab defines how time units are displayed or input
- Calculation tab to setup default calculation parameters
- Cost tab is responsible to default cost parameters and
calculation
- Risk tab defines default risks for the Global and Local
risks.
- Tools tab define path for the external applications
