Setting up project management tool integrationYou define the path for the external applications in the Tools tab. This tab is useful if you have removed an external application or a new release of the external application is installed and RiskyProject cannot find it in the registry. You can also use the Tool tab to correct a path if you selected the wrong file for external application.
See also |
