Setting up calendar defaults
In the Calendar tab, you set up the default calculations for project schedules. Actual project calendars are set up in the Working Time dialog box. The specific calendars and type (Deterministic or Probabilistic) are set up in the Main Project Settings.
  1. Click the Schedule tab. In the Settings group, click Options.
  2. Click the Calendar tab.
  3. Enter in the daily, weekly, and monthly translation values in the fields provided.
  4. Select the date format in the Output Date Format box.
  5. Enter a default start date for tasks in the New Task box. New tasks can be started on current date or default start date. Default start date is defined in Project > Main Project Settings > Project Start Time. If new task supposes to start on current date and different date is defined in Project Start Time of the Main Project Settings dialog, new task will be constrained Start not earlier than.
  6. Use the Show Deadlines and Show Resources on the Gantt chart check boxes to select whether you want to view them on the Gantt chart.
