Risk Templates
Risk templates allow you to quickly add risks to your project and
assign chance of occurrence and outcomes. Risk templates are
different from the Risk Register: they contain information about
risk assignment. Risk templates are useful when you want to:
- Move risk assignments between different projects
- Perform risk assignment as you did in a previous
project
- Manage different sets of risk assignments for
different types of projects
Creating a risk template
Create
set of global risk assignments.
Once you have created a set of global risks in the Globabl risk view, you can
save it as a risk template.
- Click the Risks tab. In the Export/Import group, click
Save
Risk Template.
- Provide a name and description.
- Click OK. RiskyProject automatically saves the
files. If the template already exists, warning will open.
Loading a risk template
Risk Assignement and then Open Risk Template.
The Open Risk Template dialog box opens.
- Click on a list to select it.
- Click OK. The template risks will replace any
global risks that exist in the project.
Selecting a default risk template
When
you select a template as the default, the template is loaded
whenever you create a new project.
Risk Assignement and then Open Risk Template. The Open Risk
- Select the check box to the left of a template to set it as the
default template.
Using risk templates for local risk assignments
Open the Risk tab located in the Task Information dialog box or the Resource
Information dialog box.
Click Load Risks from Template button. The Load Risks from Template dialog box
opens.
Select the template from the list and click OK. The risks template will
overwrite all existing local risks for the particular task or resource.
Templates may contain risks assigned to both task
and resources. If you load a risk template from Task Information dialog box,
resource risks will not be loaded. If you load risk template from Resource
Information dialog box, task risks will not be loaded.
Risk Register
