Risk Report View
The Risk Report is a view, which present attributes of selected risks. Report for one risk may contain one or many pages. Total number of pages per report equals number of selected risks multiplied on number of pages per risk.
The Risk Report includes six sections:
  1. General Properties
  2. Pre- and post- mitigation probabilities, impact and score
  3. Cost of Risk
  4. Custom Properties
  5. Waterfall Chart
  6. Mitigation Plans
Each page of the risk report contains footer and header. Footer or header may include up to three lines of text and logo located on the left or right or the footer or header. You can customize the risk report:
  • Select the order and turn on and off any section of the report
  • Customize each section by enabling and disabling any attribute and customizing labels of the attribute. For example by default the label for risk detailed description is called “Description”. Instead you may use “Information about risk”. -
  • Customize the footer and header. You can add your company logo.
  • Bold the for attribute values oand labels
To customize the risk report:
  1. On the Risks tab, in the Risk Views, click Risk Report.
  2. At the bottom of the view click Customize Risk Report.
  3. Select section of the risk report and change the order of the sections
  4. Enable/disable attribute, customize attribute’s label, make label or value of the attribute bold
  5. For “Pre- and post- mitigation probabilities, impact and score” of the report enable or disable pre and post mitigation matrixes.
  6. Click OK. Report will be regenerated to reflect the change
Reports
