About Project TasksWhen you first start RiskyProject, the Gantt view opens. Start the scheduling process by adding tasks. Each task should have a name and a base duration. You may enter this information directly onto the datasheet or using the Task Information dialog box. Opening the Task Information dialog boxThe Task information dialog box can be used to enter task parameters (duration, start, finish times, assign resources to tasks, assign risks, etc.). You can open the task information dialog can in invoked using one of the following ways:
Entering task name and durationWhen you create a task, the first step is to enter a name and a base duration.
The default Start Time for tasks is defined in the Calendar tab of the Options dialog box. The start time can be either the current date or a project start date, defined in Project ->Main Project Settings. You can always change start time using constraints (see Start, Finish Times and Constraints). You can also change other default parameters in the Options dialog box. Define task durations using the Base Duration column. Once you have added all of the tasks, you can add uncertainties by assigning low and high durations. See Define Distributions for Start Time, Cost, and Duration for more information. See alsoProject Tasks |
