Project calendars
The project calendar defines the working and nonworking days and times for tasks. This calendar usually represents your organization's traditional working hours. RiskyProject uses this calendar to schedule tasks that do not have resources assigned. By default, the Standard base calendar is used as the project calendar, but you can reflect alternative schedules by using other base calendars. The working days and hours in the project calendar reflect the working days and hours for your whole project. You can specify special days off, such as company holidays.
Project calendar can be deterministic and probabilistic. Probabilistic calendars are useful for modeling uncertain scheduling conditions such as weather. Both deterministic and probabilistic project calendars can be selected from the list of available calendars in the Main Project Settings dialog (Project menu).
Probabilistic Calendars
Create A Base Calendar
Creating a new project
Defining working time
