Working with Images and PicturesYou can copy or save images associated with all charts and all views with the exception of the Resource and Simulation Results charts. Images can be copied to the clipboard as metafiles or bitmaps or saved as a JPEG file. Copying an image from a chartRight-click on the image and choose a copy command. You can also copy the content of a view (e.g. Gantt view) to the file or clipboard Copying the content of a viewClick the Schedule tab. In the Format Group, click the Copy Picture button. Click OK to create an image of current view. To export data to clipboard separate DLL (RiskyProjectJPEG.dll) is used. The DLL is registered during installation. If the DLL is missing or not registered, you will not be able to create JPEG files. See also |
