Defining working time
RiskyProject allows you to define multiple calendars. All calculations
are done internally in hours and minutes.
- Click the Schedule tab. In the Schedule and Calendars
group, click Working Time..
- Select a calendar from the Calendar list. There
are five calendars provided:
- Standard
- Morning Off
- Afternoon Off
- 24 hours
- Night Shift
- If you need to modify the selected calendar, click on a day in
the calendar. The working and nonworking time is displayed in the
schedule on the right. You may define working for specific weekday.
To do it just click on weekday and modify working times for the
weekday. You may also specify working time for the specific day. To
do it just click on specific day and modify working times.
- Click on an hourly period to set it as working or nonworking
time. White is working, pink is nonworking.ing.
- Once you have completed the calendar, click OK
to save the changes.
Defining work for task types
