Creating a new project
The original view for a new document is defined in the Options, View
tab. The default view can be the last view in the previous
RiskyProject session.
- Click the File menu and choose New. The new project file opens.
- Click the Save button and type in a project name.
- In addition to projects files created in RiskyProject, you can also
open files that have been saved as a Microsoft Project XML or MPX
format. These formats are industry standards for project management
software and are supported by Microsoft Project and many other
project management software applications.
- MPX format is a legacy Microsoft Project format supported by many applications.
MPX format may not contain some scheduling information fields. For example, it
does not distinguish between material and work resources.
