How correlated risks are calculated
Risk correlations can only be defined in the Global Risk Assignment
or Local Risk Assignment views.
- Right-click on the risk and choose Risk and Mitigation
from the shortcut menu.
- Click the Correlations tab.
- Select a risk from the list of all available risks.
- Select the task or resource to which this risk is assigned. This
is required when risks with the same name are assigned to different
resources or tasks.
- Click OK to save this information.
Risk Correlations
