Assigning local and global risks - Local Risk views
You can define local risks using the Local Risk Assignment (Tasks) or Local Risks Assignment (Resources) Views. This is the preferred method when you have risks with the same chance of occurrence, outcome, result and moment of risk assigned to many tasks.
By default, this view is not shown in the Risk workflow bar. You can open this view by clicking the All Views button in the Workflow bar and selecting Local Risks (Tasks).
  1. Click either the Local Risk Assignment (Tasks) or Local Risk Assignment (Resources) view.
  2. Select one or multiple tasks or resource to which you want to assign this risk.
    • If you select one task you may create risk and sub risks using Indent and Outdent buttons, delete risks, paste risks, etc.
    • If you select multiple risks, only common risks for these tasks will be shown. Common risks should have the same properties.
      For example, if a risk in one task or resource has a 15% chance of occurrence and a risk with the same name in the second task or resource has a 16% chance, these risks will not be shown in the view. You will have to update their properties individually. Moreover, if at least one mutually exclusive alternative for the risk is different between the two tasks, no resources and alternatives will be shown. If you select multiple tasks, you may only copy these risks and cannot paste, delete, or create summary risks.
  3. Enter information about risk (Name, Chance, Outcome etc..)
