Assigning local and global risksOnce you have added your risks you can start assigning your local risks to tasks and resources. You cannot assign the same local risk to both a task and a resource. RiskyProject offers a number of ways how risks can be assigned to task and resources. Method 1: Assigning global and local risks using risk register
This is a preferred method for assigning risk in complex project.
This method is also useful when you edit risk assignment, for
example for mitigation planning. You will be able to view all risk
assignments in one place. With the risk register, you can assign
both local and global risks. Method 2: Assigning local risks using the Global Risk Assignment view
This is a preferred method for global risk assignment. You may use
this method for assigning local risks based on global risks. If you
have global risks, you may assign it to one of many task and
resources at the same time. Method 3: Assigning Local Risks using the Local Risk Views
You can define local risks using the Local Risk Assignment (Tasks)
or Local Risks Assignment (Resources) Views. This is the preferred
method when you have risks with the same chance of occurrence,
outcome, result and moment of risk assigned to many tasks. You can define task risks in the Risk Tab of Task Information or Resource Information dialog boxes. All risks entered here are “local risks” and will not appear in the Global Risk Assignment view. It is a preferred method if you want to assign few different risks to few separate tasks and resources. See also |
