RiskyProject Interface
RiskyProject supports a multi-document interface. You can open and
close multiple project schedules during one session in RiskyProject.
Modifying the Workflow Bar
You may modify
the Workflow bar by inserting and hiding views.
Any changes you make to the Workflow bar becomes the default for all
projects.
- Right-click on any button in workflow bar.
Click on Hide Icon to hide selected icon.
Click on Insert Icon… to insert unused icon to
the workflow bar. If the icon is already inserted to any of the tab,
it cannot be inserted again.
Click on Set Default Icons if you wish to
restore default set of icons. By defaults, all icons are enabled
except for Local Risk Assignment (Tasks) and Local Risk Assignment
(Resources).
Application Look
You may change color and style of title bar, toolbars, and status
bar, as well as change theme for the datasheets. The theme is used
for any grid including grids inside dialog boxes.
Changing the application look
On the Tools tab, in the Resources
and Settings group, click Application
Look… Formatting Gantt Bars
You can modify the shape and color of Gantt bar. You can do it for
specific tasks or for specific types of task: standard tasks,
summary tasks, milestones, etc.
Formatting Gantt Bars for All Tasks
Click the Schedule tab. In the Settings and Options group, click
Format Gantt
Bar.
Formatting Gantt Bars for Selected Tasks
- Select task or a group of tasks
- Right-click on Task ID and choose Format Bar…
On the Schedule tab, in the Settings and
Options group, click Format Gantt Bar.
Formatting the Risk Matrix
Reports
